Seafoam on new plugs = bad idea?
Old Oct 16, 2006 | 08:53 PM
kevinCHOPTICON's Avatar
Finally got new plugs (damn #8!!!) and wires in this weekend at 80,000 miles on my 00' SS. Then did some reading on the board and found out sea foam is the all god for a tune ups and thinking i might have ****ed up by not doing sea foam first then changing the plugs. My question is if it's worth my time to sea foam my car or if it will just foul my plugs and make it to where I have to replace my plugs again. I don't think my engine is that dirty as I use the injector cleaners from auto zone semi regularly (5,000 miles or so) but just thought I'd ask first to see if I should just buy some new plugs or not
Old Oct 16, 2006 | 09:04 PM
teke184's Avatar
Re: Seafoam on new plugs = bad idea?
it's designed to clean the carbon buildup off the inside of the combustion chambers....the spark plugs are in the combustion chamber...so in theory it should clean them off.
so if they are new...it should have no affect what so ever
seafoam on brotha!!!!
smoke the neighbors out
Old Oct 16, 2006 | 09:09 PM
Bayer-Z28's Avatar
Yep, no hurtey new sparkey plugs...
Old Oct 21, 2006 | 03:21 PM
wrd1972's Avatar
The smoke cloud is awesome.
Old Oct 21, 2006 | 03:52 PM
myslowcamaro's Avatar
is that when you dump it in the power brake booster line? i have a can, waiting to do it somewhere where the noise and smoke wont bother the neighbors.
Old Oct 22, 2006 | 12:08 PM
93Phoenix's Avatar
I never got that much smoke when I did it to my car, with 124k too!
Old Oct 22, 2006 | 06:22 PM
GhostZ28's Avatar
you dump it in the brake booster line then shut off the car as soon as the car empties. then after a half hour or so, start it back up and bellow out some white smoke for about 20 miles
Edit: 900 posts woot
Old Oct 22, 2006 | 06:53 PM
xpndbl3's Avatar
new plugs or not it shouldn't matter...now if it was fogging oil for storage then i'd replace plugs afterwards, but sea foam will just clean it all out
Old Oct 24, 2006 | 07:40 AM
AL SS590 M6's Avatar
Moderator
Just did the 03 Sierra 5.3 yesterday. Has 51000 miles on it and the smoke cloud only lasted about 1/2 a mile.
Old Oct 24, 2006 | 03:14 PM
GhostZ28's Avatar
aw thats too bad. mile lasted my entire ~16 mile highway trip. I exaggerated a bit on how much smoke was coming out... but it was nearly 20 miles before it cleared itsself out
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
