Help!!
Old Oct 14, 2006 | 08:32 PM
mike12032's Avatar
Help!!
I have 2000 z28. The ac compressor is going bad. The berrings are about shot. It's expensive ti fix. I was woundering if any knew if I could just bypass the compressor, and get a shorter belt? Would it work? Is there anything else I would need other than a belt. Thank's for your help in advance.
Old Oct 14, 2006 | 09:31 PM
AL SS590 M6's Avatar
Moderator
Re: Help!!
AC has it's own belt. Just remove it.
Old Oct 15, 2006 | 09:01 AM
mook99TA's Avatar
Re: Help!!
Or remove it all together
Old Oct 15, 2006 | 09:06 AM
Moderator
Re: Help!!
Not if he plans on fixing it. It's better left in place to keep the system sealed 'till he gets a new pump.
Old Oct 15, 2006 | 10:18 AM
mook99TA's Avatar
Re: Help!!
He never said he wanted to fix it. He said he wanted to bypass it. So why not take out the entire system and save some weight?
Old Oct 15, 2006 | 05:05 PM
mike12032's Avatar
Re: Help!!
Thank's for your responses. I am planning to fix it. I didn't know there was two belts. Some people told me once the compressor goes that's it. The belt will snap and I'll be stuck on the side road. Thank's for your help.
Old Oct 15, 2006 | 09:31 PM
Greed4Speed's Avatar
Re: Help!!
My compressor crapped out and my belt never broke. I drove it that way for over 6 months until I got it fixed. Just don't turn your AC on and the pulley won't engage or pull your fuse like I did.
Old Oct 16, 2006 | 08:59 AM
Moderator
Re: Help!!
He never said that he wanted to remove it. So why would you assume that bypass means remove.
Old Oct 16, 2006 | 12:41 PM
mook99TA's Avatar
Re: Help!!
it was a suggestion! That is all why so touchy?
