spohn panhard bar
Old Oct 10, 2006 | 06:16 PM
CLEAR's Avatar
spohn panhard bar
does a non adjustable panhard bar from spohn improve centering the rearend or would it be a waste to get a non adjustable. my rear is not centered and i can get this panhard off of a wrecked car right now pretty cheap but its a non adjust tubular. this car also has non adjustable spohn trackbars. would those benefit much?
Old Oct 10, 2006 | 07:31 PM
al 96 Ram Air T/A's Avatar
Re: spohn panhard bar
You can only center an out of line axle with an adjustable bar.
Old Oct 10, 2006 | 07:43 PM
CLEAR's Avatar
thats what im thinking even though all the sites say that the non adjust re centers the axle and the adjustable is for lowered cars. i mean it might be worth it to see if it changes at all and it should handle a lil better
Old Oct 10, 2006 | 10:31 PM
If the new bar is longer or shorter than OEM, than yes, it can move the left wheel in or out from the centerline. However, since aftermarket non-adjustable bars are supossed to be the same legth as the OEM bar, it will not move the axle fore or aft. Take a look at how the bar mounts. One side attaches to the body of the car, the other the axle. A longer bar will push the axle to the left, a shorter will pull the axle to the right.
Old Oct 11, 2006 | 08:02 AM
ABA383's Avatar
Adjustability everywhere is your friend...Adjustable SFCs and PHB are always a good idea especially if you plan on racing it at all...
--Alan
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
