crazy starting issues
Old Oct 8, 2006 | 09:09 AM
cb94ta's Avatar
Well my ta has finally got me at wits end, it basically does nothing when you first turn the key after a few seconds sometimes a little longer it fires off just fine, but then once it gets hot it still hesitates but it also turns over for a little bit before it fires off I've replaced the starter, the fuel pressure regulator had gone out so I replaced it with an adjustable one I really don't know where to look from here to solve it any ideas?
Old Oct 8, 2006 | 10:46 AM
johnny6's Avatar
Re: crazy starting issues
When was the last time you changed the plugs/wires? Does the car missfire at all? It could be a timing issue, go to autozone and use one of their timing lights. My friends old 98 formula had a similar starting problem and it turned out to be a timing issue.
Old Oct 8, 2006 | 11:59 AM
cb94ta's Avatar
The plugs and wires are new as well
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
Jessie4tin
Jan 7, 2015 08:53 AM
