Koni assembly "check"
Old Oct 7, 2006 | 10:08 AM
al 96 Ram Air T/A's Avatar
Just want to make sure I'm doing it right, so I wanted to bounce this off of you...
I'm using the lower spring perch (front). I popped off the old spring mount (ruuber ring) from the perch of the Decarbons. That sits on the Koni perch. Then goes the spring, and on top of the Koni...the large washer (provided by Koni). Next the upper shock mount, then the dog-bone rubber, then finally the nut.
I just want to be sure I'm not suppossed to be reusing anything else from the Decarbon's. The old dust boot does not appear to be needed as the Koni's have their own. The only thing that looks "odd" is how the shock mount sits on top of the Koni. Underneath the mount, I'm using the large washer provided by Koni. This washer sits directly on top of the Koni (metal on metal). Is this correct?
Old Oct 9, 2006 | 12:12 PM
Sam Strano's Avatar
Re: Koni assembly "check"
Looks right to me.... Don't forget there is a plastic indexing part that sits on the lower perch, underneath the spring to make the springs pigtail fit the flat perch.
Old Oct 9, 2006 | 08:22 PM
Thanks Sam...I stumbled on that part as I was throwing out the old shocks.
Everythings in. Will road test it tomorrow...
Old Oct 10, 2006 | 10:27 AM
Sam Strano's Avatar
Enjoy!
Z Power
Sep 19, 2015 11:19 PM
Henson071
Sep 18, 2015 04:01 PM
JJOHNROE
Sep 8, 2015 05:39 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
