Where to hook up remote wire for sub
Old Oct 7, 2006 | 08:55 AM
mook99TA's Avatar
Where do you hook up your remote wire for an amp to the stock monsoon radio in a 99 TA?
Old Oct 7, 2006 | 09:12 AM
LS1 RULZ's Avatar
Re: Where to hook up remote wire for sub
Headunit wiring harness
Pin#............Color.................Function
1...............Grey..................Front Left Speaker -
2...............Tan...................Front Left Speaker +
3...............Dark Green............Front Right Speaker -
4...............Light Green...........Front Right Speaker +
5...............Black.................Ground
6...............Brown.................Illumination
7...............Grey..................Dimmer
8...............Pink..................Power Antenna
9...............Yellow................12V Ignition
10..............Orange................12V Constant
11..............NA....................NA
12..............NA....................NA
13..............NA....................NA
14..............Dark Blue.............Steering Wheel Controls
17..............Light Blue............Right Rear Speaker -
18..............Dark Blue.............Right Rear Speaker +
19..............Yellow................Left Rear Speaker -
20..............Brown.................Left Rear Speaker +
Old Oct 7, 2006 | 01:02 PM
mook99TA's Avatar
So I take it you hook it up to the pink antenna wire. If so couldn't you just hook it up in the trunk where my antenna is so its a shorter run of wire?
Old Oct 7, 2006 | 04:57 PM
LS1 RULZ's Avatar
You could but some folks like to do it at the radio so you can add a switch to lower the antenna whenever you want and still have remote turn on control of the amp.
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
themushine
Sep 3, 2002 10:02 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Snake Slayer
Jul 29, 2002 12:39 PM
