Front Hub Question
Old Sep 29, 2006 | 08:00 PM
barney1golf's Avatar
Front Hub Question
Can you replace the bearing in the front hubs, or do you have to replace the whole hub? Car is a 97 Z28 6-speed
Old Sep 30, 2006 | 02:31 AM
lincmarkv's Avatar
Re: Front Hub Question
Sealed hub. Replace the whole thing.
Old Sep 30, 2006 | 12:07 PM
fragglerock's Avatar
I have to replace the 2 front assemblies on my 95z28, is that easy to do? Do I need anything special to get the old ones off/put the new ones on?
Thanks!
Robert
Old Sep 30, 2006 | 02:01 PM
OBE1 95Z28's Avatar
Hub assemblies are easy to swap, remove the brake caliper, remove the brake disk, disconnect the ABS sensor connector and unbolt the hub.
You'll need to install wheel studs onto the new hub.
Old Sep 30, 2006 | 02:34 PM
n2ceptor's Avatar
I didnt on my '93Z....
Old Sep 30, 2006 | 03:18 PM
respectirocz's Avatar
personally i've never seen a hub that comes without studs installed
studs are easy to install anyway
Old Sep 30, 2006 | 06:54 PM
so I don't need a press right? Thanks guys
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Hurin
Dec 13, 2014 07:38 PM
1LEThumper
Jul 14, 2003 12:45 PM
