My Panhard rod fell out while driving!
Old Sep 24, 2006 | 10:38 PM
Huntr1117's Avatar
So I'm driving in a school zone on Friday and I take a left turn. All of a sudden I hear something dragging under my car. So I pull over thinking that I'm dragging something that I ran over. I look under the car and my panhard rod is hanging down from the drivers side still attached to the passenger side! The bolt was completely gone. I put a new panhard rod from UMI about 2 years ago and I know that all the bolts were tight. Guess I should have bought the new bolts. At least the panhard rod is still good, only the bushing got a little scraped up. No one has the bolt, now I have to get the dealership to order one. Have you ever heard of this happening?
Old Sep 25, 2006 | 06:21 AM
RE AND CHERYL's Avatar
Re: My Panhard rod fell out while driving!
You should be able to go to a local hardware store and get one. It's just a nut and bolt. Pull the other one to get the right size.
Re'
Old Sep 25, 2006 | 07:09 AM
Sweetred95ta's Avatar
Re'
That's what I was going to say. It will save you some money and time (waiting for the bolt to come in). Use some thread-locker this time. I've never heard of that happening though.
Old Sep 25, 2006 | 07:29 AM
87DJP2001's Avatar
Make sure you use "Grade 8" fasteners and not the cheap hardware stock.
Old Sep 25, 2006 | 08:21 AM
NOSCaMaRo's Avatar
The pnahrd bar bolt is a tappered bolt, not something you will find at a hardware store and can only be purchased from GM. If you need to use a hardware store bolt a 1/2" will work but will be loose and may cause some noise.
Old Sep 25, 2006 | 08:26 AM
2000GTP's Avatar
I ended up buying those bolts directly from Spohn when I ordered the LCAs and PHR. I'm not sure how much the dealership cost is compared to that.
Old Sep 25, 2006 | 11:54 AM
al 96 Ram Air T/A's Avatar
As a matter of fact, I just ordered these bolts from Pontiac on Saturday. They run about $1.50 each, and are 14mm to 12mm tapered grade 10.9 bolts.
Old Sep 25, 2006 | 09:32 PM
Huntr1117's Avatar
I found a chevy dealership in Houston that had the bolt. I still can't believe that the bar fell while I was driving.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rje
Sep 9, 2002 12:35 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Trevor98ramair
Jul 31, 2002 02:43 PM
