Just installed 4:10s: Excessive whine when turning: plz HELP!
Old Sep 23, 2006 | 10:32 AM
johnnyb's Avatar
So i just got done installing richmond 4:10s in my TA. They whine at low rpms, but when you turn right, either a sharp turn or even going around a curve, they make this god-awful-ear-piercing-howling noise. What could be the cause of this? I installed new bearings (except axle bearings) and used asolid pinion spacer if that makes any difference. thanks
Old Sep 23, 2006 | 11:12 AM
CamaroSS30thAnn's Avatar
Re: Just installed 4:10s: Excessive whine when turning: plz HELP!
not sure if this is a common problem when turning , but my buddies 4.10s do this to
high gears like that do whine alot tho
Old Sep 23, 2006 | 12:02 PM
LesPaulGoth's Avatar
Did you set the backlash correctly? This would be my first guess, and might turn into a bigger problem than just a high pitched whine =/
Old Sep 24, 2006 | 07:35 AM
johnnyb's Avatar
i believe the backlash is correct- it was about .008 and it called for .010 +/- .004 . im going to tear it apart today and reset everything. i just wasn't sure why it would make the real loud noise when just turning right- i thought maybe that had to do with something specific and someone would know
Old Sep 24, 2006 | 08:17 AM
anaik's Avatar
Isn't turning noise caused by not having added friction modifier?
Old Sep 24, 2006 | 11:11 AM
That was going to be my next guess. When you filled up the oil, did you add the Posi fluid?
Old Sep 24, 2006 | 05:30 PM
johnnyb's Avatar
problem solved. i took the cover off the rear this morning and noticed that there was a little play left and right. i reshimmed the carrier bearings to fix the slop, rechecked the backlash, (set at .006) and everything is a- ok
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
mattszm6
Dec 14, 2014 07:09 AM
Elcojoe
Nov 17, 2014 10:27 PM
