Replacing DRL on left front
Old Sep 21, 2006 | 03:46 PM
lantern's97Z's Avatar
How do you replace the bulb, do you have to pop out tha amber lens of go from the inside of the fender, Are the bulbs expensive ? thanks
Old Sep 21, 2006 | 04:09 PM
ACE1252's Avatar
Re: Replacing DRL on left front
There is a black access panel under the front corners of both fenders(Just in front of the front tires). Take the bolts out, take the panel off, and you will then be able to see the connector for the bulb. Twist roughly 90* and it will come out. Replace it, put everything back together, and you are set.
Old Sep 21, 2006 | 05:10 PM
Thank you much sir
Old Sep 21, 2006 | 07:16 PM
rickjames343's Avatar
The bulbs are like 4 bucks for a set of two.
blac94Z
Jan 16, 2015 11:03 PM
Jazsun
Dec 29, 2014 12:14 PM
70rs00z-28
Sep 6, 2002 08:13 AM
