Rear end rebuild parts?
Old Sep 10, 2006 | 05:43 AM
ctmallam's Avatar
I have a 98 Z28 M6 with traction control and ABS, 168,000 miles on it. The rear end is making popping noises when I back up and drive slow around corners. I think my differential and bearings are bad. It also leaks around the pinion seal.
I'm going to rebuild it and have put together a list of parts. Is there anything else I might need, besides tools? Thanks.
Eaton Posi Unit 10 bolt GM 7 1/2 - 7 5/8 $399
GEARPKG Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt Rear Ends $399.99
69-G875410 Gears: Motive 4.10 Gear Ratio, 3 series carrier
108-01300 Gear Oil: Royal Purple Gear Oil
85-3001K Install Kit: Ratech Deluxe Kit $35.00
16-TA-1809 TA Performance Products Rear End Cover, 7.5" GM 10 Bolt$154.99
16-TA-1815 TA Performance Products Main Cap Stud Kit, GM $24.99
20-1052358 GM Limited Slip Fluid Additive $6.99
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
