Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
Need a shop to build a custom cage?
Old Aug 28, 2006 | 09:40 AM
1 DWN CAM's Avatar
Anybody know of a place in So Cal that builds custom cages? I need a custom 6pt that is also NHRA legal.
Old Aug 28, 2006 | 10:48 AM
cnorton's Avatar
Re: Need a shop to build a custom cage?
A 6-point unit would technically be called a "roll bar" rather than a "cage." The difference in cost is substantial. Be sure that the design you pay for is congruent with the specs on page 210 of the 2006 NHRA Rulebook. There are descriptions of what needs to be included in the design if you have frame connectors or don't have them. A swing-out side bar is also very convenient.
A local shop that does a lot of NHRA and PSCA chassis work is PMR Racecars on Arrow Highway in Montclair. PMR built my complete 4th generation F-body Super Stock chassis. I'm in Covina if you'd like to see a sample of their work.
Phil Mandella's phone number at PMR is (909) 621-5531.
Good luck
Old Aug 28, 2006 | 02:32 PM
1 DWN CAM's Avatar
Thanks for the info. What kind of setup did they do for your vehicle? Also what kind of pricing would I be looking at? and turn around time?
Thanks.
Old Aug 28, 2006 | 06:32 PM
cnorton's Avatar
My car has a full cage, full tubs, aftermarket disc brakes, 9" Ford housing, etc. but then, we built the entire car there over the period of a year. The chassis is certified for E.T.'s as low as 8.50 and would only require a minimum upgrade to be certified for 7.50. It sounds as if you are looking for the roll bar instead of a cage.
The price would depend on the material used and the cost of materials fluctuates with the price of steel. Some people are willing to sacrifice the lower weight for a cheaper price by using mild steel. Most of the NHRA stock/super stock cars are built using chromemoly tubing. The time factor will depend on the backlog of work at the shop. I don't want to throw out any numbers for either cost or timeline because I'm not there every day and I don't know exactly what the situation looks like. The best thing do do is wait for Phil to come back from the U.S. Nationals in Indianapolis right after Labor Day.
c
Old Aug 28, 2006 | 10:45 PM
truedualws6's Avatar
Gene's Mufflers in Downey can build whatever you want.
(562) 923-4814
Ask for Greg.
Old Aug 29, 2006 | 10:15 AM
1 DWN CAM's Avatar
Thanks for all the info.
Old Aug 29, 2006 | 01:17 PM
slowpoke310's Avatar
try haddad motorsports in Inglewood
Haddard (Mike)
Business Information:
Company: Haddard (Mike)
Address:
423 Florence #10
Inglewood Ca
Phone: 310-412-8032`
Fax: 310-412-8035
Old Aug 29, 2006 | 11:15 PM
1 DWN CAM's Avatar
Thanks, but that might be a little out of my range distance wise. But I'll keep a note of it.
Old Aug 30, 2006 | 12:19 AM
bsim's Avatar
Thumbs up Re: Need a shop to build a custom cage?
www.redzoneracefab.com did my cage, they're in Simi. Tell Nick that Brad sent you...very reasonable.
Old Aug 30, 2006 | 09:41 AM
1 DWN CAM's Avatar
WOW!!!! Is that mild steel or moly???
Old Aug 30, 2006 | 07:19 PM
bsim's Avatar
Nope, not moly, but it was an option he gave me. The incremental cost wasn't that much more if I recall.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Collector Car
Jan 5, 2015 10:58 AM
kev311
Jul 20, 2002 11:07 PM
