speaker noise
Old Nov 12, 2002 | 08:29 PM
slayer6x6's Avatar
Angry speaker noise
ok, so far i have 2 amps, one for the subs and another for 6x9s and they are both running through an eq. the problem is that when i shut my car off i get a rapid tapping sound only from my 6x9s, i have no idea what would cause that noise, any suggestions would be helpful, thanks
Old Nov 12, 2002 | 09:19 PM
TechCam97's Avatar
Mine did somethin similar. It turned out to be a loose ground connection.
Old Nov 13, 2002 | 01:19 AM
NineSevenWS6's Avatar
What kinda radio is it? Id lose the EQ. Theyre so 80's. Could be bad ground as suggested above, or a possible problem with the remote wire, although, if the subs dont do it, and use the same remote, you can pretty much rule that out.
Old Nov 13, 2002 | 01:42 PM
slayer6x6's Avatar
its a kenwood exceleron
Old Nov 13, 2002 | 03:24 PM
Id lose the EQ for sure then. Test the remote wire after the deck is off, see if its still giving voltage to the amp. Dont forget the ground as well.
Old Nov 14, 2002 | 04:28 PM
slayer6x6's Avatar
Angry
ok, i gave the amp a solid ground and then after that i took the deck out to check the connection on the remote wire and now i am not getting any power to the remote wire straight out of the head unit. something weird is goin on.
Old Nov 14, 2002 | 05:07 PM
bman555's Avatar
EQs seem to cause weird affects like that sometimes. Some of them change the voltage being sent to the amps so it may be a cause for your initial problem. Or...
It sounds more like that remote wire si the problem and may be loose either at the amp or the head unit. I'd re-run that wire and see what happens.
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Bxlt1
Sep 10, 2015 08:16 AM
rideordie
Sep 7, 2015 08:22 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
