Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
View Poll Results: What do you think of "HInk's tip of the Month" series?
Excellent Idea.
34.78%
Okay... I guess!
4.35%
This is being cheap.
17.39%
HInk must be off work on a short term disability.
10
43.48%
Voters: 23. You may not vote on this poll
HInk's tip of the month!
Old Nov 12, 2002 | 05:00 PM
Redbird's Avatar
Arrow HInk's tip of the month!
Lets face it... we all like to save money, if and when possible. Where can we save a few bucks when we are re-gearing our rear ends? I use Royal Purple in my rear housing. With a T/A cover it now holds about 3.5 quarts. At $9.99 a quart or so, it's a darn shame to just dump it, especially if it is under a couple of years old (drag strip years are even less).
Simple solution and you can save the cost of new fluid. As you drain the fluid, drain it through a couple of coffee filters. This leaves me with a very nice and clean fluid to reintroduce into the housing when finished and saves me over $35.00.
Watch for "HInk's tip of the Month" next month!
HInk
Old Nov 12, 2002 | 06:10 PM
PhantomTA's Avatar
Moderator
Ive used Royal Purple once and never will again..
I was using Mobil, however Redline for me!
Old Nov 13, 2002 | 07:00 AM
transamtom's Avatar
Wink
Hink,next months tip:How re-refine your motor oil to give it that just changed look J/K Kevin
Did you see much metal when you did it?
Old Nov 13, 2002 | 09:34 AM
cASe SenSiTive's Avatar
Exposed Member
The oil doesn't only get dirty. It also becomes degraded from the many heat cycles it's put through. That's why you should use new fluid.
Old Nov 13, 2002 | 09:52 AM
turbolx's Avatar
Talking
HInk.... send me some of those filters and I'll gladly send you a few cheap bottles of "Recycled Beer" too!
Old Nov 13, 2002 | 10:38 AM
Redbird's Avatar
Exclamation
DON'T EVEN TRY THAT EXCUSE TOMMY!!! What is the differenc if I change gears once every two years and recycle the fluid a couple of times and you leaving your fluid in for 70,000 + miles?? Guess it doesn't break down until it hits the outside air, huh?
At least I've filtered out some of my contaminents! If I was using the normal cheap dino stuff, I would'n sweat the $2.99 for a quart! BESIDES! Synthetics don't lose their lubricating values like other, CHEAPER fluids.
Greg... I don't drink fresh beer let alone the Pabst beer you've filtered with your kidneys and liver, which I might add are wearing out quicker than mine!!
HInk
Old Nov 13, 2002 | 10:50 AM
Exposed Member
Who said anything about leaving it in for 70,000 miles???
You're just trying to save money so you can afford the attourney for that little "rest area" arrest you had a while back, aren't you?
Old Nov 13, 2002 | 11:08 AM
Redbird's Avatar
Arrow
TOM:
I got a case of 'GREG'S BEST' ordered for you, buddy! The way he drinks Pabst, you outta have it tomorrow!! CHEERS TO YA!!
Kevin (I got the same lawyer you have!!)
Old Nov 13, 2002 | 06:21 PM
turbolx's Avatar
Exclamation
WHOA!!!!!!!!!
The Bullsh!t stops here, fellas. I DO NOT drink Pabst..... Labatt Maybe, Pabst NO. I feel like I'm slumming it when only Bud Light is available, but rest assured you would be getting "filtered Blue."
Old Nov 14, 2002 | 01:28 AM
TheNovaMan's Avatar
Not that I condone the reuse of gear oil, but let's think about it hypothetically. I have 85W140 in my 12-bolt right now, and that stuff was like molasses when I poured it in. It'd probably take a year for just one quart to pass through the filer, so what do you do during the 3.5 years it takes to filter it?
Just buy some new oil, HInk.
Old Nov 15, 2002 | 09:22 AM
DJ_951's Avatar
Hint 2: Don't fix that front seal and intake oil leak Just add a quart of oil every month and change the filter every 6 months. No more oil changes
P.S. I like Pabst beer
Old Nov 15, 2002 | 12:25 PM
MichiganSkip's Avatar
Hey, That's my tip of the week! Plus if your leak is big enough, you don't even have to change filter! My beater runs 3 quarts through every 1000 miles. Buy cheap Wal-Mart oil at less than a buck a qt. No muss, no fuss, no having to get rid of the used oil!
Skip
Old Nov 18, 2002 | 02:37 PM
Redbird's Avatar
Arrow
The reuse of rear fluid after a year of drag racing is quite different than the reuse of fluid after 50,000 miles. Plus... I don't use the cheap stuff, I use Royal Purple.
As far as that intake leak, I pulled my intake last year and have NO leak! Guess it's just a matter of knowing what you are doing when reassembling.
The Royal Purple I use is 85-140 and isn't like molasses, you must use the CHEAP stuff.
HInk
Old Nov 18, 2002 | 07:15 PM
TheNovaMan's Avatar
I would never put anything cheap in my car. As a matter of fact, I have Royal Purple 85W140 in my 12 bolt. I should point out that it was probably about 50ºF when I put it in, and man was that stuff thick!
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
USN06
Sep 7, 2015 03:30 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
