fuel pumps ... what are you using?
Old Aug 20, 2006 | 08:29 AM
bowtiepwr's Avatar
>I have the Walbro 255 340m intank and Vortech inline.
I want the Weldon, but which and is there anything wrong with the Barry Grant King Sumo pump? I know someone here had a bad experiance.
Old Aug 20, 2006 | 08:52 AM
Schurters LT1's Avatar
Re: fuel pumps ... what are you using?
Twin in take set up, Bought it from http://www.lonniesperformance.com/ get guy...
With the parts in this kit YOU can not put it together cheaper
Old Aug 20, 2006 | 08:21 PM
TransAm396's Avatar
wow..thats expensive...if each pump is 110(220$) where does the other 380 come from??
Old Aug 20, 2006 | 08:35 PM
CALL911's Avatar
I personally am running dual in tank Walboro's. I have a Hobbs switch hooked up to my intake, and when it reads that I am running more than 4#'s of boost, the Hobbs switch kicks in the 2nd fuel pump. Everything works great with the exception of the rubber hoses falling off the pumps during driving at first. I have since switched to braded in tank lines, and have not had an issue since.
Old Aug 20, 2006 | 08:40 PM
TransAm396's Avatar
how much did it cost to make the kit?
Old Aug 20, 2006 | 09:05 PM
xxsaint69x's Avatar
running that kit at as well...couldn't be happier and gladly paid extra for how plug and play the kit is. For some reason i dont trust myself with wiring a fuel pump etc eheh
Old Aug 20, 2006 | 09:06 PM
TransAm396's Avatar
oh what exactly does it come with?-Mark
Old Aug 20, 2006 | 09:25 PM
Just email Lonnie,
He will give you all the info...there is not a better kit out there...
Old Aug 20, 2006 | 09:40 PM
T/A KID's Avatar
What size injecters are you guys running. I see a lot of success from others with the Ractronix plug and play intank fuel pump, 60lb motrons, and a KB boost-a-pump. Rich Krause on this board made 733RWHP and 8XXRWTQ with basically the above setup (He was using 70lb injectors I believe) On average I think that is the recommened fuel setup for 650-700RWHP, anything above that Dual intakes are needed.
How much power is everyone Pushing??
Old Aug 20, 2006 | 09:42 PM
TransAm396's Avatar
Really?? Im only looking to make 650rw MAX next season...anymore info on that?
Old Aug 20, 2006 | 09:53 PM
Rich also had LJ low inp convert box...
that set up would work as well....
Old Aug 20, 2006 | 09:56 PM
You might be able to get away with
Ractronix plug and play intank fuel pump, 60lb motrons, and a KB boost-a-pump or MSD BAP as that is a P&P with the racetronix kit ....
Old Aug 20, 2006 | 09:57 PM
TransAm396's Avatar
about how much would that cost me total?I cant find the BAP anywhere
Old Aug 20, 2006 | 10:02 PM
TransAm396's Avatar
thats only 100$ cheaper than the double pump setup...how reliable would the racetronix and MSD pump booster be? Seems like it would fry the pump with all that power going to it..
Old Aug 20, 2006 | 10:42 PM
xxsaint69x's Avatar
just get the racetronix dual walbro setup from lonnies
