VATS system wont let car start...
Old Aug 18, 2006 | 02:35 PM
CADEman98's Avatar
So, my car won't start...'98 V6 Camaro...
Had a friend look at it, said the peice that reads the key resistor was bad...so he put a resistor into it...it worked for 2 days...
then it wouldnt start again...
so he wired the ignition directly to the fuel pump and the starter. It worked for 2 days, and now it wont start again...or, it will start but its very finicky.
I don't want to start it up and it get me stranded somewhere.
So, my buddy said the end all be all to this problem would be to get the VATS system removed, but no whre around here will be able to do it on v6 camaro's.
What do i do?
Old Aug 18, 2006 | 03:45 PM
MustangEater82's Avatar
Re: VATS system wont let car start...
Read up on bypassing the VATS system. Go to gen tech and do a search. You can do it, not to knock your friend but maybe he is just not doing it 100% right, It obviously can be done since you were able to start it.
Or you could just spend $27 and get a new key.
Old Aug 19, 2006 | 07:41 PM
CADEman98's Avatar
all the writeups i've found for the car where for older and newer V8's, i cant find anything specific about v6's?
Old Aug 21, 2006 | 05:35 AM
its the same
Old Aug 23, 2006 | 06:28 PM
CADEman98's Avatar
Originally Posted by MustangEater82
its the same
I'm pretty sure he did it right, he's been doing it for a while
and the key: I tried my spare key, that hasnt been used in a while, and it still wouldnt start...
Old Aug 23, 2006 | 08:03 PM
It it wasn't the key and the VATS, there is a good chance its just a bad starter switch?
I had one go out on my 94 back in like '01. It would very sporadically start. I have seen a few peopel with the problem as well.
its possible that is it. Maybe try asking in the Gen tech section...
Old Aug 23, 2006 | 11:40 PM
CADEman98's Avatar
Alright, i've pretty much narroed it down to the VATS system is just being a PITA. Where can i find somewhre to ship my BCM to that will re-program it so that the car will start w/o needing the VATS signal?
fpete1992
Dec 11, 2014 03:51 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
lbrowne
Nov 13, 2011 04:25 PM
