1993-1996 Delco radios.... 101
Old Aug 16, 2006 | 10:44 PM
TraceZ's Avatar
I've been spending some time messing around with these Delco radios. I've got some things to share.
First off... The radio is made of 3 basic components that seperate easily, with no real electronic skill required.
1) The face / display / ***** and buttons
2) The CD mechanism
3) The tuner / amp / preamp
All of these style Delco radios have section 1 and 2 in common. If it is Bose or not does not matter. The components are interchangable.
section 3 differed between Bose and non bose. In my pictures you can see both side by side. The heat synch is the obvious give-away. The Bose has the small heat synch because there is no internal amplifier. The Bose system uses external amps. The more robust heat synch is for the standard non-Bose model with onboard amp.
Any of these Delco radios can be converted from Bose to non-Bose and back by simply swapping out section 3 of the head unit. Pretty cool, huh!
In my Z, I'm running a Bose section 3. It has line level outputs that I run to my Soundstream 5 channel amp. Bridged to 3 channels, running components in the doors and a sub in the trunk it sounds pretty decent.
Here are the pics:
Also posted at www.f-body.com
Old Aug 17, 2006 | 06:10 AM
RE AND CHERYL's Avatar
Re: 1993-1996 Delco radios.... 101
In my 94 I just modified a unit form a 2002 malibu (same as F bod unit), swaped the connector and unsed it. Looks and performs a lot better and still has a factory look.
Re'
Old Aug 17, 2006 | 06:28 AM
Mtrhds94Z's Avatar
Good info.. interesting..
I knew they were modular, and came apart like that, but didn't know the Bose/reg Delco similarities..[I have only messed w/Bose HU's]
I had CD unit go bad, and swapped one.. now I know I can get a reg Delco HU, and use the CD unit for the Bose..
Thanks!
Old Aug 17, 2006 | 10:51 AM
Flip94ta's Avatar
wow thanks for the good info, I knew I should not have bougth that alpine
magman
Apr 15, 2016 03:08 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
