Camaro interior trim question
Old Aug 15, 2006 | 08:25 AM
Midn8t's Avatar
Hi, I was going to replace the interior trim now the dash and so forth. but the door panels, side panels in back seat, the rear trunk panels on the side along with the door below plastic kicker trim along the seat.
I was wondering if i replaced it what could i replace it with ?
what mounts up to it ?
I been looking for exact same style car well kinda i belive that i can use replacement interior panel parts from 1993 to 1995 pr 96 camaro ?
but i was wondering if trans am same years would work ? I kinda like the door panel on the trans am with the speaker setup. so i guess i was curies how it would setup if i was to do replacement using trans am interior panel for the doors ?
i was also curies if i was to replace the dash what is there any othere cars panels that would fit for the dash that would mount up okay ?
friend of mine said that senes and i think may be right seens majority trans am / fire bird and camaro are about the same i also think that gto is about same so i was wondering if GTO interior panels would fit up im not sure i guess if theres big diffrince with way this stuff will mount up in a 1994 camaro z28 ?
if it fit right i guess ?
i did a search on forums but i was not sure what to searh for so my search results did not come up with to much so i thought id ask something and see what i get for answear.
thanks for the time.
Old Aug 15, 2006 | 01:15 PM
bunn_69's Avatar
Re: Camaro interior trim question
kinda seems like u are in the same bost i was in lol just check the web sites on this form http://web.camaross.com/forums/showthread.php?t=466275 and put ur cars info in and see if u can find what your looking for. It might help or might not just a good place to look
Old Aug 15, 2006 | 01:32 PM
Midn8t's Avatar
thanks i was am pretty sure the trans am mounts would work and im pretty sure anything with in 3 years of my car should work.
but thanks ill check out that url.
Old Aug 15, 2006 | 02:28 PM
Craddock's Avatar
You can put any interior from a 93-02 Camaro or Trans Am, it just may take a little modification. It's been done before though.
Old Aug 15, 2006 | 06:12 PM
94Z28WP's Avatar
All the interior panels are interchangable without modification except the T/A and Z28 door panels... I just installed T/A door panels in my Z28 and I had move the three door panel mounting points in order for it to fit.. All the switches plug right up except the power mirror switch... You'll need the plug from the T/A and it has to be rewired... As far as the dash, any 93-02 T/A or Z28 will bolt right into place... But you'll have to do some rewiring for the gauge cluster and extend some of the wires for the hatch release, etc... Not all hard to do, just time consuming.
Old Aug 16, 2006 | 07:56 AM
Midn8t's Avatar
thanks for info I was just curies what all my options where.
and i really do like the Trans am doors. with way they do speakers.
Hurin
Dec 13, 2014 07:38 PM
bernie1951
Dec 10, 2014 10:03 AM
ChrisFrez
Dec 7, 2014 06:01 PM
owen66
Nov 30, 2014 04:21 PM
Zomie
Jul 22, 2002 07:43 AM
