Powerdyne and belt slippage
Old Aug 14, 2006 | 11:14 AM
NJ-LE's Avatar
I find I have to retension every couple of weeks. Has anyone tried very thin cross-cuts on the supercharger pulley to eliminate belt slip? Is there an 8 rib set of pulleys available (cost?)? Someone mentioned a Ford truck belt tensioner could be used to tension another brand of supercharger (ATI ?) but never identified what model Ford it was from. Is that piece or something similar usable on a Powerdyne?
Old Aug 14, 2006 | 12:17 PM
Kredz28's Avatar
Re: Powerdyne and belt slippage
Have you tried tightening the hell out of it or even buying a new belt?
Old Aug 14, 2006 | 01:58 PM
NJ-LE's Avatar
I retighten until the belt is very firm. I switched to one of the Goodyear "Gatorback" belts and assumed it would take a few cycles to get the initial stretch out of it but months later it still will slip. A few weeks after tightening it will start slipping ~ 4500 rpm. Belt and pulleys are clean and dry.
Old Aug 14, 2006 | 03:29 PM
Kraest's Avatar
Retired
Powerdynes =
Sorry for your loss.
Old Aug 14, 2006 | 03:58 PM
Sparkz28ss's Avatar
this guy
Old Aug 14, 2006 | 03:59 PM
cjmatt's Avatar
use belt dressing, its kinda sticky. it helped mine out alot
cjmatt's Avatar
Old Aug 14, 2006 | 08:23 PM
30thTA0525's Avatar
tighten it dress it.. replace belt, tighten it dress it.. replace belt, repeat again again again... good luck
Old Aug 15, 2006 | 08:56 AM
NJ-LE's Avatar
Smile Re: Powerdyne and belt slippage
Thanks for the replies guys. I was just surprised to find that the "low pressure" Powerdyne had slip problems. I hadn't read of that and thought owners had a fix. Perhaps my unit not broken in yet. (only about 2000 miles on it ... it also is "adult driven" so it doesn't get hammered everytime it's on the road. http://web.camaross.com/forums/images/smilies/smile.gif
Old Aug 15, 2006 | 06:58 PM
BadgeZ28's Avatar
http://www.katechengines.com/street_...etail.php?id=1
Old Aug 16, 2006 | 03:37 PM
NJ-LE's Avatar
Lightbulb Re: Powerdyne and belt slippage
Thanks for the KaTech reference. I'll give them a call. Though the text on that page seems to say the tensioner is fixed (they call it solid-adjustable). It does seem to have an 8 rib belt pulley and the 928 Supercharger guy has an 8 rib head unit pulley available. I think I can mod the Powerdyne crank pulley to use an 8 rib. My concern was an 8 rib tension pulley. The P-Dyne is a composite and I was leery of trying to alter it.
Old Aug 17, 2006 | 03:37 PM
pavement pounder's Avatar
You can get back some psi with a Reichard racing pulley http://need-4-speed.com/reichardracing.htm
I made 1 myself, it took me a whole day to it right but it works for me
Old Aug 17, 2006 | 04:34 PM
NJ-LE's Avatar
Question Re: Powerdyne and belt slippage
"Pavement Pounder"
Did you just slot the surface of the pulley or did you drill the holes under the slots too?
Old Aug 17, 2006 | 05:02 PM
bowtiepwr's Avatar
...Someone mentioned a Ford truck belt tensioner could be used to tension another brand of supercharger (ATI ?) but never identified what model Ford it was from. Is that piece or something similar usable on a Powerdyne?
>MY T-trim came with the Ford tensioner I can get you the part # if you want.
Old Aug 17, 2006 | 05:05 PM
bowtiepwr's Avatar
>Vortech part # 4GV011-032 I'll get the Ford part # too
