Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
subframe connectors
Old Aug 14, 2006 | 10:11 AM
pj97ragtop's Avatar
subframe connectors
what happens when you don't preload the suppension. if you use a frame hoist there is no weight on the wheels. thanks
Old Aug 14, 2006 | 12:08 PM
SSpdDmon's Avatar
Re: subframe connectors
The car was designed to perform with the suspension loaded. When you lift a car, you redistribute the weight from the wheels to the subframe. This will alter the car's form slightly due to natural flex. If you weld up the frames while in this position, you're locking in that flex and will put additional/abnormal strees on the car when the weight is transfered back to the wheels. To make a long story short, there's a right way and a wrong way to do it. When the suspension isn't loaded...that's the wrong way.
FYI - there's a suspension forum. You should try there next time.
Old Aug 14, 2006 | 05:08 PM
pj97ragtop's Avatar
thank you for info. this will help me where to take it to.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
