seperate Nitrous fuel system.
Old Nov 12, 2002 | 01:57 AM
slp223's Avatar
I want to run a 1 gallon fuel cell with c16 my questions are what are my fuel pump options? Could I use a FI pump and run line pressure at 45 psi and jet it the same as a taped set up. Or if I run a carb pump at 6-8 psi and compensate the jetting how much fuel would the pump have to flow. Would a standard Holley pump work? I have seen a set up like this using the Holley blue pump but is that over kill? Any opinions would be appreciated.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
