How many quarts for t56 if filled throught shifter?
I am about to get the trans back in, I plan to just pour the new fluid in through the shifter. I am using Penzoil Synchromesh, how many quarts should I pour in?
Re: How many quarts for t56 if filled throught shifter?
4 quarts....not sure the specs on Pennzoil Synchromesh but all T56s require Dexron III fluid. Might wanna make sure whatever you pour in says Dexron III on it somewhere. If it says Type F anywhere, that's the wrong stuff....
Originally Posted by tmb
Why are you filling through the shifter? isnt there a fill plug on the driver side of the t56?
The pump is $5.00
Yes, $5.00.
http://www.partsamerica.com/ProductD...egoryCode=3243
I'm working on my '72 Vega in dirt. Literally, dirt. Doing a V8/6-speed swap. I don't cut corners even when I get stickers and **** in my shirts. I guess it boils down to how many corners you want to cut.
http://www.iroc-z.org/72LT1vega.jpg
I also did the 5-lug conversion on my car and has a 12-bolt with 3.73s.
Hey man, do it however you want but if you have too much oil in your trans and it foams and takes out the gearsets you are the only one to blame.
Make a set of wood stands to drive your car onto for next time. I can drive my IROC up about 2 feet in the air in about 2 minutes. No jack required.
Colin
Colin
Well, I cant belive this got bumped back up nearly 2 years ago. Anyways I am going to be changing the fluid to dextron soon it shifts a little knotchy. The trans was freshly rebuilt when I filled it through the shifter so there was no fluid left in it. Why the hell would I want to do it hte hard way when the shifter was already off?
Oh yeah, maybe the tranny is shipped bone dry. Oh yeah maybe they have a small amount already installed just in case some dumbass does not fill it at all. It does need some amount of lube for assembly. They can say dry all day long but I am confident that it aint dry.
Newly rebuilt does not mean dick with respect to how much fluid is in it or not, you dont know if a small amount of fluid was added or not. At least the correct method of installing fluid removes ALL possibility of overfilling.
Why someone would pay hundreds for a rebuild then fill the tranny with the assumption its shipped dry is just stupid.
It's not like he's taking the shifter off, it's already off. Why would he want to do it under the car?
