T76 or bigger?
Old Aug 9, 2006 | 10:12 AM
ChrisUlrich's Avatar
T76 or bigger?
For making 900-1000whp on race fuel, stock pcm, stock castings, but custom cam. Bottom end, fuel, ignition, etc...
625-650whp on pump gas and close to 1000whp on race fuel!! Think a T76 will be able to support that?
Old Aug 9, 2006 | 10:37 AM
Eric@Victory Racing's Avatar
Re: T76 or bigger?
This is the one we are using for a customer that wants to achieve 1000rwhp.The new S88 uses the latest in compressor and turbine wheel technology. The new TM1 turbine wheel flows massive amounts of air and still spools quickly for its size. This unit will support 1575 HP respectively.
Old Aug 9, 2006 | 10:47 AM
Re: T76 or bigger?
S88 eh? That sounds interesting! Sounds like something I should invest in... :-)
Old Aug 9, 2006 | 01:23 PM
RealQuick's Avatar
Re: T76 or bigger?
I have a GT42-76 (76mm) with a T6 1.15 A/r for sale if your interested. Its rated for 1200fwhp. It pushed a 3300# mustang to 155mph in 1/4 @ 20psi. It has ~10-12 passes on it, thats it. Practically new.
Old Aug 9, 2006 | 01:51 PM
96PTKZ28's Avatar
Re: T76 or bigger?
What are you doing for a turbo kit?? I went with the PTK gen 2 and a 76GTS which will get you to around 900rwhp if done correctly. Good luck doing that the right way with a stock ECU though.I have never heard of the S88 but it wont fit on the gen 2 kit if thats what you are planning. The 76 is as big as it gets, but should meet your above listed expectations.
Old Aug 13, 2006 | 11:00 AM
96PTKZ28's Avatar
Re: T76 or bigger?
One more thing. Forced Inductions offers a 80mm upgrade for the 76GTS that I have decided to go with. It is said to up power by around 100HP so you are looking at a max of 1,200FWHP. I doubt there are many on the street so should be interesting to say the least. And who wants a 76mm when you can have an 80mm!?
Old Aug 19, 2006 | 08:31 AM
JohnnyPappis's Avatar
Re: T76 or bigger?
I wasent aware of that upgrade looks like plans might change just a little bit
Old Aug 19, 2006 | 03:12 PM
96PTKZ28's Avatar
Re: T76 or bigger?
Johnny- The 80mm upgrade looks like the ticket for those with a PTK gen 2 or any kit where you dont want to hack your car to hell to fit an 88 or something similar. It works especially well on a smaller cube 355 setup. Jose has sold several to LS1 guys who seem to be very happy with them. Mine will be the fist one on an LT-1 car. I am excited to see what it will lay down. Give jose a call and get some info on the upgrade.
Old Aug 19, 2006 | 03:16 PM
RealQuick's Avatar
Re: T76 or bigger?
Keep us posted, the prospects seem promising!
magman
Apr 15, 2016 03:08 AM
Hal Fisher
Sep 30, 2015 09:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
nd4spd200
Aug 21, 2015 09:30 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
