spraying BIG for a season
Old Aug 7, 2006 | 12:25 AM
95custom's Avatar
well, I have upgraded fuel system, and want to spray big for a season. I have stock bottom end, My car will be out in 07 (LT1) and will rebuild after the season is over. What duel stage kit is recomended? I am looking for 200+
Old Aug 7, 2006 | 12:00 PM
jldak318's Avatar
Re: spraying BIG for a season
200 on a stock bottom end lt1? i would have to say you are crazy. if u want the motor to last till 07 u can prob start spraying Denember 31 or 2006 at 11:59. u might be able to get away with it once or twice but them stock pistons arent gunna like that much gas on them. this is just my 2 cents.
Old Aug 7, 2006 | 11:00 PM
Joe B's Avatar
MANY guys that are spraying the regular kit provided and recomended 125 HP and 150 HP shots (with ZERO problems) on stock bottom end LT1's, are really spraying quite a bit more at the crank.... Many of the popular nitrous kit manufactures are using aproximate "rear wheel" horsepower ratings now, instead of "crank" HP........so spraying around 190-200HP at the crank isn't really all that crazy at all , even for the stock bottom end.........Iv'e been doing this on my stock bottom end since 1998, and now with the mods in my sig since around December of last year(not a single problem)..just make sure it never goes lean, and you have every available failsafe for added insurance.......I would talk to harrisspeedworks about what your wanting to do, and have them recomend one of their kits for you...I currently run NOS stuff, but will be using Harris in the near future for a bigger kit on the new build(good products and support).....Joe
Old Aug 13, 2006 | 01:13 AM
95custom's Avatar
thank you, yes, 200 shot on stock bottom end is not crazy, and is easily doable for a season.. Can you tell me who harrisspeedworks is, and how I can contact him? PM or post.
Old Aug 14, 2006 | 11:45 PM
Bandit 1's Avatar
http://www.harrisspeedworks.com/shop/home.php
Run a single stage with a progressive controller
Jeff1904
Jun 5, 2016 05:00 PM
Sep 18, 2015 03:46 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
