cylinder misfire
Old Aug 4, 2006 | 09:17 PM
DLindlZ28's Avatar
cylinder misfire
on night i was racing and i messed up on shifting i went from 3rd to 2nd trying to hit 4th yeah i know i really screwed up! anyhow my car begain to run like crap so i change the plugs with ngk tr55 and wires with msd8.5 and it still ran bad so i took it to xxxmotorsport and had a guy check my pushrods he said some where bent so he changed all of them out and checked the motor for other damages and it was fine and now i have a bad misfire out of cylinder 6 rechecked everything and i cannot fiqure this one out(and my coils are fine to all working) plz help
Old Aug 5, 2006 | 08:45 AM
AL SS590 M6's Avatar
Moderator
Re: cylinder misfire
Probably bent a valve. Do a compression test.
Old Aug 5, 2006 | 08:07 PM
DLindlZ28's Avatar
compression is pefect on all cylinders ,maybe one of the valves are stuck open or closed im not sure
Old Aug 5, 2006 | 08:20 PM
RussStang's Avatar
You used a comma (although not entirely correct), but still use no period?
It could be a bent valve. How much was the motor over revved on the botched shift?
Old Aug 6, 2006 | 09:06 PM
ManicHaze's Avatar
i would have guessed bent pushrods too, but i see you have replaced them...so I don't know then if it isnt a valve.
good luck!
Old Aug 9, 2006 | 08:05 PM
DLindlZ28's Avatar
as soon as i hit 2nd i pulled the car outta gear so it didnt over rev much if any some times the ca runs fine and othe days it will run like crap and with the air conditioning on it really bad
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
