hi-flow cats
Old Aug 4, 2006 | 02:48 PM
SpeedDemon02SS's Avatar
hi-flow cats
How raspy will the car be with out cats? How much louder? Is it equivelant to cats and a cut-out?
Old Aug 4, 2006 | 03:06 PM
Re: hi-flow cats
ok...i have an SLP dual/dual muffler set up. Same one from factory...the '345hp system.' Its not too loud. So how bad will that be with no cats and LT's?
Old Aug 4, 2006 | 03:13 PM
ulakovic22's Avatar
Re: hi-flow cats
A stock exhaust with no cats will be loud but not that bad since the stock exhaust is so restrictive and you don't have headers.
Old Aug 4, 2006 | 03:16 PM
Re: hi-flow cats
its not stock exhaust, it was the exhaust performance option from factory. same as the center mount, just with a dual/dual.
Old Aug 4, 2006 | 03:17 PM
2000GTP's Avatar
Re: hi-flow cats
In terms of loudness, there was no difference from when my car just had the long tubes and off-road y-pipe to when I had a shop weld in a pair of high-flow cats. As for the raspiness, if there is any, the cats should help clean that up.
Old Aug 4, 2006 | 03:24 PM
Re: hi-flow cats
well, i dont want cats..i have a major clearance issue, and when i go with the LTs, i dont want to have cats to scrape the ground.
Old Aug 4, 2006 | 03:27 PM
miaminick's Avatar
Re: hi-flow cats
Not to hijack your thread or anything, but what's the best flowing cat to buy?
Old Aug 4, 2006 | 03:34 PM
Re: hi-flow cats
well, i was looking at the hooker comps...and they sit very tight to the car. so there isnt room for the cats. the cats will actually hit the floor boards.
Old Aug 4, 2006 | 03:35 PM
2000GTP's Avatar
Re: hi-flow cats
Its possible you may drag them with those lowering springs. The band clamps shouldn't be a problem, just position the clamp so that the bolts aren't pointing straight down.
Old Aug 4, 2006 | 03:41 PM
Re: hi-flow cats
the lt's will be fine, as well as the clamps. i drive the car alot, so i dont want it to be deafining.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
