Moser 9" Leak
Old Aug 3, 2006 | 01:59 PM
OBE1 95Z28's Avatar
Moser 9" Leak
Thought I'd share a problem/solution in case others have this issue. I've got a Moser 9" housing and axles that has had a leak at the axles from day one. I replaced the seals that press in the axle tubes, replaced the o-rings in the end "plate" with no luck. I decided to take it to a shop and they discovered that the axle is tampered in the area where the axle tube seal mounts. This diameter should be constant as it needs to mate with the seal. They added 0.100" shims and new seals to move the seal further out on the axle to increase the diameter of the axle shaft to get a good seal. Time will tell if it's fully cured.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
