Quick Zex Question
Old Aug 3, 2006 | 08:31 AM
BananaBelly's Avatar
Quick Zex Question
I am about to buy a used base zex dry kit off of a friend of mine who had it hooked up on his f150. It was basically the bottle, WOT switch and the purple solenoid box.....My question is, will i be able to hook up a window switch and purge etc too this kit later on...As far as i know now, it would switch on as soon as it is WOT and i dont want it spraying under 3k.
Old Aug 3, 2006 | 08:43 AM
01Z's Avatar
01Z
Re: Quick Zex Question
There's more than one way to set an rpm window. In my case I'm using a mallory ignition box to break or enable the ground to the solenoid(s). My kit is wet and I don't boost fuel pressure but I still think you can add an rpm window switch that breaks or enables the ground to your WOT switch and auxiliary fuel pump, if that's what you have.
Old Aug 3, 2006 | 09:28 AM
DrewHMS97SS's Avatar
with the purge, you can hook that up before the zex box and after the bottle.
so, bottle, long feed line, purge, short line, zex box, so on.
Old Aug 3, 2006 | 09:36 AM
I would essentially do the same for the rpm activation switch correct?
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
Brendans Z
Sep 11, 2002 05:29 PM
