1998-2002 driveshaft question
Old Jul 28, 2006 | 08:01 PM
98mustang_vert's Avatar
Is the driveshaft the same in all stock LS1 vehicles? I'm going to replace my 1998 10 bolt with a 10 bolt from a 2001 trans am, a friend of mine said that some of the driveshafts were steel and then later switched to aluminum. Will this affect me when I replace the 10 bolt?
Old Jul 28, 2006 | 08:10 PM
87DJP2001's Avatar
Re: 1998-2002 driveshaft question
It makes no difference if its steel or aluminum they are the same. But my choice would be the LS1 aluminum dr shaft.
Old Jul 28, 2006 | 09:50 PM
MyShibbyZ28's Avatar
The alluminum ones are lighter, and sometimes reduces vibration. Otherwise, they are the same.
Old Jul 28, 2006 | 11:07 PM
Thanks guys, I appreciate the quick replies and info
Old Jul 29, 2006 | 07:39 AM
Capn Pete's Avatar
Unless there was a mix-up at the factory, ALL LS1 6-speeds got aluminum shafts, and the 3.23 geared autos got aluminum as well. Only 2.73 geared autos got the steel shaft.
AFAIK, LT1's all got steel, unless they had the 1LE package?
Old Jul 30, 2006 | 09:06 PM
turbotko's Avatar
Unless they had the vibration fix done under the TSB like I did Free aluminum driveshaft.........can't beat it!!
Old Jul 31, 2006 | 06:31 AM
teke184's Avatar
steel or aluminum....doesn't matter...they are all interchangable.
even from the 3rd gens, the LT1s, the v6s and the LS1s....all interchangable.
Old Jul 31, 2006 | 11:44 AM
Capn Pete's Avatar
Sweet deal!
Old Jul 31, 2006 | 01:35 PM
No... the 1993-97 V6 models have a two-piece driveshaft, with a center support bearing bolted to the torque arm. They might "fit", but I wouldn't suggest putting one of those in a V8.....
Old Jul 31, 2006 | 03:30 PM
teke184's Avatar
ok ok....you got me on that....
geez ...you f-body nerd!!!
Old Jul 31, 2006 | 05:40 PM
Capn Pete's Avatar
What's the point of those driveshafts anyways???
Old Aug 1, 2006 | 02:16 PM
Are you asking why the V6's came with a 2-piece driveshaft? I believe it was to eliminate some harmonics that resulted from a combination of the V6 firing pattern and a straight shaft. 93-97 V6 owners have been know to swap in one-piece shafts with no problems, though.
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
