Help with vibration (already searched)
Old Jul 27, 2006 | 07:23 AM
PatriotTA's Avatar
OK, so I already did a huge search and turned up nothing. My problem seems to be different than what everyone else is experiencing. It goes like this...
Vibration occurs above speeds of 80mph or so. It is felt though the car body, shifter, and clutch pedal. Its quite extreme. You can feel it in the clutch pedal when you just barely have your foot touching it, not depressing it at all. Now here's the kicker - vibration goes away when I push in (disengage) the clutch. Let the clutch out (still at 80+mph) and the vibration returns.
I'm really thinking its not my DS or U-joints or gears or tires, since disengaging the clutch doesn't make them spin any slower. The car has a Pro 5.0 shifter, SLP clutch package, 4.10 gears, stock steel DS, and poly trans mount. That's all the mods that should matter.
Any ideas?
Old Jul 27, 2006 | 08:49 PM
UnslowZ's Avatar
Re: Help with vibration (already searched)
Check youre pressure plate does it have any burnt spots I.A.Friction wear
Old Jul 28, 2006 | 07:33 AM
96TurboTA's Avatar
That won't cause a vibration.
Old Jul 28, 2006 | 02:52 PM
OBE1 95Z28's Avatar
Pushing your clutch in isolates the engine (flywheel) from the clutch/PP and rear drivetrain as long as you're still in gear. So this would point to an engine/flywheel balance issue. If the engine/flywheel were out of balance, it should be rpm dependent, not speed dependent. Try slowly reving up the motor in neutral while parked in your driveway; what do you feel?
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
alliance12364
Sep 17, 2015 08:43 AM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
