ABS Inop after longtube install
Old Jul 26, 2006 | 06:02 PM
KillerTA's Avatar
I started my 97 ta up after installing longtubes and "ABS Inop" comes up on the dash as soon as I start it. I'm clueless as to why.
Old Jul 26, 2006 | 10:42 PM
KillerTA's Avatar
Re: ABS Inop after longtube install
I checked my brake lights after reading other posts, and they are fine.
Old Jul 30, 2006 | 06:32 PM
matLT1's Avatar
Did you by chance disconnect the speed sensors up front during the install and forget to reconnect them? I'd take a look at those.
Old Aug 1, 2006 | 08:34 PM
KillerTA's Avatar
What are those located by? I don't think I did.
Old Aug 1, 2006 | 11:43 PM
blackztpi's Avatar
its pretty common for a wheel sensor to set off the abs inop light. i have the same problem with my light after pulling the motor and redoing it. not sure whats up, but i have other issues to worry about right now. i'll let you know when i get to it.
Old Aug 3, 2006 | 11:18 PM
Red_94Formula's Avatar
Yea the header on the passenger side is right next to the passenger side ABS sensor wire. Follow that ABS sensor's wire and you may notice a connector that is burnt to a crisp that just happens to be right next to a header. That happened to me and a friend.
Old Aug 4, 2006 | 11:40 AM
2000GTP's Avatar
This is a pretty common mishap, I believe I secured that wire harness away from the header with some cable ties in order to avoid cooking it.
Old Aug 4, 2006 | 05:32 PM
KillerTA's Avatar
I don't think that's it because I zip tied the wires about 1/2" away from the headers during the install plus they have a silver heat shielding on them.
I noticed the abs inop light a few minutes after startup because I wasn't paying attention to the dash at first. I think it probably went on immediately at start up.
Nov 18, 2023 07:21 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
