Valve cover idea
Old Jul 24, 2006 | 07:21 PM
'97 30th Anniversary Z/28's Avatar
Question Valve cover idea
I recently installed a P1SC on a LT4 conversion/hotcam motor and my drivers side valve cover started leaking, my solution is to get a drivers side centerbolt valve cover from a non lt1 or get another pass side lt1 valve cover and flip it over. Run a BF 412 in each cover and tee them together and tie it into the intake side of the S/C. Add breathers to the fill cap holes and I should be in business. Any thoughts
Old Jul 26, 2006 | 02:55 AM
AmericanMuscle33's Avatar
Re: Valve cover idea
I recently did a similar thing. I swapped on a pass valve cover to the driver side, and ran tubes from the breather holes into the exhuast (for suction). Worked extremely well...In the crankcase evacuation literature, it mentioned the sysem actually works best if you seal all other holes off....i.e. the fill holes, I just have two fill caps tightened in place.
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
