My back window is really blurry (help)
Old Jul 21, 2006 | 11:45 AM
CAMARO16's Avatar
I tried windex already and it did almost no help. Do you think i should wash it with soap? Its inside the car though so its gonna be hard. I have no idea why its so blurry but when i look in my mirror i cant see out my back window. What should i try doing ?
Old Jul 21, 2006 | 01:13 PM
stroked 383's Avatar
Re: My back window is really blurry (help)
Hey, I checked out your car domain page and saw you have tint on the back window. Whatever you do, do not use any cleaners on the tint that have ammonia in them...it'll make your tint turn that purplish color. Does it feel like there is some kinda grease on the window, or is it just hazy? Soap and water would prob work, or maybe even some simple green thinned in some water would do the trick too. Just be very careful, I used some windex only 1 time and my windows all turned that purplish color in less than a month...had to have a re-tint! I did one bang up job cleaning them though... You can use wadded up newspaper as well to eliminate any streaks- just use it just like a rag, it'll soak up the fluids and get easier to use after it gets kinda sogged.
Good luck
*They also have special window cleaner made for tint at about any autozone type automotive place*
Old Jul 22, 2006 | 11:24 AM
EHuff's Avatar
I would try some Stoners window cleaner. Last time I was at Walmart they had some there. If not just do a Google search for it and you can find there website and maybe you can order it offline. This cleaner is strong on dirt and grime but soft on tint. Give that a try and it should work for you. Also the best way I found to clean the back window was to take your shoes off and sit in the back seat and climb up through the opening to the rear area and just sit there with your feat dangling off in the T-Top area. Just be careful though not to bang up your plastic interior pieces. Hope that helps you.
Old Jul 24, 2006 | 11:38 PM
pcgamer4life's Avatar
I had a can of freon blow up in my hatch and my glass was impossible to see out of when the light hit it. Tried windex and Invisible Glass, no luck. Soap and water were the best solution, followed by invisible glass.
maybe2fast
Mar 16, 2015 09:45 AM
warmeck
Feb 2, 2015 12:44 AM
warmeck
Jan 20, 2015 10:29 PM
The Seer
Nov 20, 2014 06:32 AM
firebirdude
Aug 7, 2002 07:31 AM
