Noise from Camaro while turning in Reverse
Old Jul 21, 2006 | 11:01 AM
kaoticcamaross's Avatar
I'm not sure what it is yet but the car makes a back squealing sound when back out of a parking space or something. I have also noticed it when driving slow in a parking lot or something. I personally have no idea what to check but its so bad that i can't take it anymore.
Old Jul 21, 2006 | 11:29 AM
RMC_SS_LDO's Avatar
Re: Noise from Camaro while turning in Reverse
May sound dumb, but check your tire pressure.
You may just be hearing the tires squealing on the pavement at low speed....
Old Jul 21, 2006 | 11:32 AM
tire pressure is just slightly below what the side wall says so I'd say thats not the problem but thanks for your input. I not sure how to describe it, whether its a squeal or a squeak but either way it's high pitched and sucks to hear.
Old Jul 21, 2006 | 11:35 AM
surf121's Avatar
If you've changed your differential oil (and have limited slip) make sure you put the limited slip additive in it. I forgot to add the oil when I changed the diff. oil in my truck about a year ago and it made some weird noises in reverse, until I put the stuff in it. Mine was more of a clunk noise, but I'm just throwing you an idea. -Logan
Old Jul 21, 2006 | 11:49 AM
Well the rear diff fluid was changed 2k miles ago by local shop so I'd have no idea if they did or didn't. What should I do
Old Jul 21, 2006 | 02:17 PM
Add some GM Limited Slip Additive. The posi unit can make some weird squeaks, pops, snaps, groans when turning slow and tight in reverse or forward, if it does not have the additive.
Old Jul 21, 2006 | 03:02 PM
how would i find out if it had the additive
Old Jul 21, 2006 | 04:28 PM
They would have to tell you. If it was not the GM stuff, it may not work well (most don't). I would just add some.
jj71787
Dec 30, 2014 02:15 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
