Oil Change Light
Old Jul 19, 2006 | 09:59 PM
blackcamaro22's Avatar
Oil Change Light
My Oil Change Light has been on for the past couple of weeks. For like 1 minute after I start my car up. Is it suppose to go off after a minute or stay on when you really need an oil change? I added two 1 litre bottles of oil to the engine so im not sure if I should reset my light. Or when I should change it next? BTW this is a 99 LS1.
Old Jul 20, 2006 | 12:29 AM
AL SS590 M6's Avatar
Moderator
Re: Oil Change Light
Why did you add oil? Did you check to see if you needed it?
You should immediatly take your car to a mechanic and have the oil & filter changed and the light reset. Then go buy a book on basic auto maintainence and read it cover to cover.
Old Jul 20, 2006 | 01:01 AM
Yah it was really low on oil. So 2 bottles filled it up perfectly. Then the oil change light came on like 2 days after I topped it off.... so grrrr. Should I play it safe and just buy all new oil and change it along with the filter?
Old Jul 20, 2006 | 05:59 AM
01Z's Avatar
01Z
Take a look at this thread: http://web.camaross.com/forums/showt...ange+oil+light
If you need an oil and filter change don't neglect that but to reset the oil change light follow the instructions above. It would be a good thing to get an owner's manual if you don't have one. A used one can be quite reasonably priced on ebaymotors.
Old Jul 20, 2006 | 03:39 PM
Greed4Speed's Avatar
YOU need to keep track of your milage and change oil accordingly. There is no dirty oil sensor, its using math to decide when your oil is dirty and environment is not a factor in that equation.
Old Jul 21, 2006 | 08:39 PM
jrangel's Avatar
if u want to reset it turn off your car turn ur key slightly but do not turn it on....
push the brake 5 times it will reset i believe
Old Jul 21, 2006 | 09:42 PM
rooster99ss's Avatar
no, to reset the oil change light, turn the key on, but don't start the car. then hold the trip odometer reset button in until the oil light flashes and goes out. the light is set to come on every 3,000 miles once it is set, but as said earlier tis best to keep up with your maintenance with your eyes on the dipstick.
Old Jul 22, 2006 | 02:16 PM
jrangel's Avatar
wow wtf u needed 2 quarts of oil... poor car
Old Jul 22, 2006 | 03:24 PM
2001NBMZ28's Avatar
At about 2 quarts low you should also throw the low oil level light.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
