M29 in a 95?
Old Jul 19, 2006 | 09:51 PM
Jeremy95TA's Avatar
M29 in a 95?
I know that the M29 came in the 93's and that the T-56 came in 94+. I was under my car the other day and I noticed that the transmission crossmember said M28/M29 and then when I was reinstalling my center console in the car it said M28/M29. Anyone know what it says that instead of T-56?
Old Jul 19, 2006 | 09:55 PM
Re: M29 in a 95?
Probably because there was no reason to re-tool or re-cast the parts because they are the same for use with the MM6 (T56).
Old Jul 19, 2006 | 10:05 PM
Dave '97 Z28 M6's Avatar
Re: M29 in a 95?
The '93s came with M28 and M29 transmissions (depending on rear gear ratio). These are both T-56's, but have different ratios (and lower torque ratings) than the '94-up T-56's.
I'm thinking that GM just didn't bother changing their nomenclature throughout the whole production process, even though every T-56 from '94-'02 was called the MM6. These Mxx are option codes, BTW.
EDIT: shoebox beat me to it!
Old Jul 19, 2006 | 10:07 PM
Pandamonkey's Avatar
Re: M29 in a 95?
Learned something new here.
Didn't know that there were two different trannies in 93. Thought there was on one......
Old Jul 19, 2006 | 10:18 PM
Re: M29 in a 95?
Here's some info, courtesy the FAQ at www.f-body.org
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU3)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
1994 Manual/MN6 2.66 1.78 1.30 1.00 0.74 0.50 3.42 (GU6)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU3)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
Year Model/Optn Torque Capacity
1993 Manual/M28 360 lbs-ft
1993 Manual/M29 400 lbs-ft
1993 Auto/MX0 400 lbs-ft
1994 Manual/MN6 450 lbs-ft
1994 Auto/MX0 400 lbs-ft
*Note that from '94-'97 there were no changes to the T-56s. LS1 T-56s have their differences (input shaft, etc.), but I believe are internally identical. Sorry for the messy copy/paste.
Old Jul 20, 2006 | 06:37 PM
Jeremy95TA's Avatar
Re: M29 in a 95?
I kinda figured they didn't bother changing their castings. Thanks guys.
Gtpguy
Parts Wanted
Apr 2, 2015 05:13 PM
pontguy
Sep 6, 2014 07:17 AM
racinmyz28
Jun 3, 2013 06:53 PM
Zeetwentyfate
Jul 2, 2012 09:47 PM
93camarochrisz28
Jan 27, 2008 10:53 AM
