Starting problem - please help
Old Jul 10, 2006 | 11:54 AM
Valkyn71's Avatar
This morning my car decided it didnt want to start while i was stopping for some food.
While i was driving previous to this, the voltage level on my guage kept dropping way down, when it did my spedometer would jump all over and the car would sometimes studder for a second.
Previous I have had problems with the car not wanting to start, when you hit the key it would start for a second, them immedietly die, or just crank and crank, and sometimes start and run, but very rough. This always seemed to go away if i just kept re-starting it, eventually it would run fine.
So this morning when i try to start it, they lights on the dash wont come on until i put the key all the way into the "crank" position, where it does nothing. All the accessories work. I thought the alternator might be bad, and just totally drained my battery, so i bought a new one and put it in. Still the same thing.
I did get the car to start once, and it seemed to run okay. I had to turn it off, and when i tried starting it again, it would make a strange clicking noise from somewhere near the glovebox.
Sorry if this post is really disjointed, im writing it durring a break in my bio class, which i was late for the test in because of this.
So if anyone can give me some insite on what you check or why its doing this, i would be in your debt.
Old Jul 10, 2006 | 01:06 PM
98mustang_vert's Avatar
Re: Starting problem - please help
I had a problem with mine a few weeks ago where it would just crank and not start. Once it would start it would be fine. Anyway, it turns out the starter and ignition relays were bad and I replaced them (located in the fuse box), best $15 I ever spent. I bought them from Kragen. You can check their website for your specific vehicle to find the right relays. Not sure if they are different on the LS1 and the LT1, but my suggestion is to start solving the little problems first, relays, spark plugs/wires, fuel filter, etc. Hope this helps. Also, here is the Fueling and Injection section of LS1 Tech http://www.ls1tech.com/forums/forumdisplay.php?f=8 lots of great info there about starting problems.
Old Jul 10, 2006 | 04:45 PM
Valkyn71's Avatar
Can you give me a part number for the ignition and starter relays? I called autozone and they said they dont have them and they might be a dealer only parts.
Old Jul 10, 2006 | 07:47 PM
Valkyn71's Avatar
I went in and messed around with it again for a minute. In the fuse box under the hood, the Ignition fuse was good, as well as the fuses in the car.
I'm thinking it has something to do with the ignition module near the key, since the time i did get it to start, it was by messing with the key a bunch.
But it also makes me think that it might be the module that is somewhere in behind the glove box, since the time it started, when i was hitting the key i could hear some noises from back in there.
If anyone can shed some light on this i would be thrilled.
EDIT: Where is the starter relay? In a thread i read it said it was in the fuse box under the hood, but its definetly not there on my car. Im guessing its in a different spot for the LT1 cars?
Old Jul 10, 2006 | 11:04 PM
The relays on my car were right next to each other. I checked the Kragen website for your car but couldn't find the relays, so maybe Autozone was telling you the truth about ordering them from the factory. I'm not familiar with the ignition module near the key, sorry I couldn't help you more. Try posting on LS1 Tech, hopefully they can help you out.
Old Jul 12, 2006 | 01:44 PM
"White Knight"'s Avatar
Have Autozone or Advanced Auto test the battery and alternator first, it's free.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
