Newb nitrous question
Old Jul 7, 2006 | 11:32 PM
frankthetank078's Avatar
with a littly modded LT1 would it be ok to put a 100 shot on it with out hurting her? thanks
Old Jul 8, 2006 | 09:45 AM
HarrisSpeedWorks's Avatar
Re: Newb nitrous question
You should be ok with a 100 shot. If you do it remember to change out your plugs to a colder set and if you don't want to spray through the shifts pick up a RPM window switch.
Matt
Old Jul 8, 2006 | 04:48 PM
2000GTP's Avatar
100 shot shouldn't be a problem at all. Alot of people do it and some even go higher on stock bottom ends. As mentioned above, just take some precautions and get the colder plugs and window switch.
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
