Bolt on or Weld in SFC's?
Old Jul 7, 2006 | 09:16 AM
black02z28's Avatar
Hey guys just wondering which is best bolt in or welded and which are the best SFC's?And are the triangler 3-point SFC's any good or should I just go with regular ones?Oh BTW I have T-Tops.
Old Jul 7, 2006 | 09:26 AM
confused327's Avatar
Re: Bolt on or Weld in SFC's?
bolt holes stretch out, whatevrer you get, weld them in.
Old Jul 7, 2006 | 10:29 AM
"White Knight"'s Avatar
Bolt holes stretch huh? So you have your torque arm welded to your rear then right?...lol
I have bolt-in SLP's and they are awesome. They feel as good as the day I put them on. I say Triangular all the way more weight, but worth it IMO.
Old Jul 7, 2006 | 11:16 AM
Bad analogy - The TA mount is a lot thicker steel than the thin sheet steel that the subframes are made out of. I've seen some nasty pictures of torn sheet metal on the subframes.
Old Jul 7, 2006 | 12:13 PM
87DJP2001's Avatar
Thumbs down Re: Bolt on or Weld in SFC's?
Welded SFC's. wasted effort fpr the bolt in ones.
Old Jul 7, 2006 | 01:56 PM
2000GTP's Avatar
I would go with the welded ones as well.
Old Jul 7, 2006 | 05:23 PM
ManicHaze's Avatar
I have the Double Diamond SFC's. I bolted them in, then welded them in. Makes it easy, the bolts hold them on while you weld.
Old Jul 8, 2006 | 10:58 PM
v7guy's Avatar
welding in the bolt ons has been popular lately, regardless, weld them in and forget about it.
Old Jul 9, 2006 | 11:38 AM
Bawls's Avatar
weld
Old Jul 10, 2006 | 08:07 AM
ATIProcharger's Avatar
I just got a pair of the bolt on UMI SFC. They are awesome and make a huge difference. Installation was really easy and straight forward. Eventually, I will have them welded to, but the shop I called wanted 60-120 to install and weld them. Figure I can save the $$ for now and just bolt them up and find someone to weld for cheap later.
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
rje
Sep 9, 2002 12:35 PM
