Changing rear gears, where can I find some heavy duty cap bolts?
Old Jul 6, 2006 | 10:50 PM
remaxracer45's Avatar
Unhappy Changing rear gears, where can I find some heavy duty cap bolts?
I'm getting ready to change the gears in my 96ws6 and have a rear girdle with the preload and wanted to upgrade my bearing cap bolts, where can I get some and what type. Anyother reasonable upgrades while I have this apart. Trying to get by for a while till I can aford a 9inch.
thanks
what normally breaks on these?
Old Jul 6, 2006 | 11:36 PM
Bow94z's Avatar
Re: Changing rear gears, where can I find some heavy duty cap bolts?
what gears are you going with?
Usually what breaks is the shock being put on the rear breaks teeth on the ring and pinion gears..with 4:10's the pinion gear is like a the size of an egg.
i bought the TA Main cap stud kit from http://www.thunderracing.com/catalog...vid=4&pcid=210
I would pick up a RaTech soild pinion spacer as well like 17$ from thunder racing aswell, Cheap insurance for the ol' 10 bolt. it replaces the crush collar in your install kit
Old Jul 7, 2006 | 12:20 PM
Wink Re: Changing rear gears, where can I find some heavy duty cap bolts?
thanks, I am going to 373 as they say less teeth a bit stronger? what are the 411 you have?
FredM
Dec 18, 2014 01:40 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
slocody
Feb 10, 2003 01:04 PM
