Y-pipe, Does 2000+ fit 1999
Old Jun 30, 2006 | 12:20 PM
eckerta82's Avatar
Have a lead on a Y-pipe off of a 02 WS6, will it bolt up to my stock 99 Z-28?
The Y-pipe is an SLP for stock headers, exhaust
I know they changed headers in 2000 or so, but are the y pipes the same
Old Jul 1, 2006 | 02:03 PM
Sylvrls1's Avatar
Re: Y-pipe, Does 2000+ fit 1999
no the pipes are diffrent
Old Jul 1, 2006 | 10:40 PM
94CamaroZ28's Avatar
Exactly how?
If it's the rear length, who cares? A little welding, all is well. On the other hand, if flanges up front are wildly different, might be more trouble than it's worth.
Anyone who knows EXACTLY how they are different, please post. I just scored a 02 SLP y-pipe and have a 98 SS 'vert. I can mod a bit to make it work, but don't want to get crazy.
Old Jul 1, 2006 | 10:46 PM
SSpdDmon's Avatar
Originally Posted by 94CamaroZ28
Exactly how?
The earlier LS1's didn't have a ball/socket flange on the passenger side. The newer ones do. You can always make it work with fabrication. But, stock for stock, bolt-up replacement - it won't work unless you get a passenger cat from a newer f-body with the other end of the flange. Aside from that portion, it should be the same dimensions everywhere else (drivers side, i-pipe end).
Old Jul 1, 2006 | 10:51 PM
Cool, thanks! It so happens I can probably score a later pass side cat no problem... other guys are frequently doing long tubes. Yup, I will too, later. For now, cheap to free is sweet...
Noer
Parts Wanted
May 4, 2015 04:58 PM
Apr 3, 2015 10:54 AM
redzed
12
Aug 29, 2002 02:22 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
