Tuning w/ and w/o SuperCharger
Old Jun 29, 2006 | 06:57 PM
joe-96z1le's Avatar
If I have a good tune for a s/c and then remove or lose my s/c belt, will the fuel tuning be way off or will the PCM & MAF adjust the fuel so I don't run rich? Isn't most s/c charger tuning done in the PE tables once the MAF has maxed out?
Old Jun 29, 2006 | 07:59 PM
Dave '97 Z28 M6's Avatar
Re: Tuning w/ and w/o SuperCharger
Are you running an FMU and an external timing control?
Old Jun 30, 2006 | 06:15 AM
joe-96z1le's Avatar
No FMU. Using 60 lb. injectors and an MSD Digital 6 with no external timing box.
Old Jun 30, 2006 | 07:19 AM
SMOKINV8's Avatar
WOT is usually compensated for that way (if you're using the MAF anyway), but you need to ask your tuner how they set it up to be sure.
You may or may not run a little rich everywhere though since the supercharger puts some load on the engine even at idle, which needs to be compensated for in fueling. However, there should be a different fueling value at the lower load, so who knows. Like I said before, talk to your tuner about it to be sure.
Old Jun 30, 2006 | 06:13 PM
How is the PCM compensating for boost? Are you running a 2bar MAP? If there's something (in the PCM or an FMU/retard box) that adjusts fuel + spark based on boost level, you could probably switch back and forth between SC/NA. Of course, if the blower is still in place with the belt removed, it will be a restriction in the airflow.
Old Jul 3, 2006 | 09:26 PM
97WS6Pilot's Avatar
There is not much difference in the tunes other than the timing and PE tables at WOT. Superchargers require a much lower A/F ratio at WOT. Also the timing is retarded in the 95 and 100KPA MAP area for superchargers. I take the belt off and run my ram air on long highway trips with my supercharger tune but I don't go WOT. No problems as long as your running MAF and closed loop.
lt1xondeck
Mar 18, 2016 07:22 PM
Highlanderrtl
Jul 24, 2015 03:34 AM
mrwz28
Jul 8, 2015 09:11 PM
CARiD
Jan 27, 2015 06:27 AM
