How do you remove the Cooling Fans???
Old Jun 28, 2006 | 07:44 PM
BadgeZ28's Avatar
I need to swap fans on a LS1 F-Body for a supercharger install. How do you remove the whole cooling fan assembly? I know I need to unplug the electrical connections, and remove the air cleaner shroud. Does the cooling system need draining for hose removal? Does the assembly come out the top or bottom? Thanks.
Old Jun 28, 2006 | 09:33 PM
Re: How do you remove the Cooling Fans???
Unplug the fans and lift the fan assy off it's mounting hooks. I wrangled mine out the bottom. Hoses will give some interference.
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
IrocSS85
Jul 18, 2002 10:35 PM
