Wiper (single) dead
Old Jun 26, 2006 | 09:48 PM
Craddock's Avatar
Wiper (single) dead
Ok, my wipers have a real bad habit of sitting about 6 or 8 inches above where they belong. Well you could always just push them down and it would be ok, but today it totally messed up. I went to push the driver side down (cause it's the side I'm on obviously when I leave the car) and it makes a loud crunch sound and goes down, but the other one stays where it's at. So now the driver side wiper is dead, and the passenger side is doing like usual. It's supposed to rain here for the next few days and tomorrow is my last day off from work so I need to fix it tomorrow if I can. Any ideas on what to do with this?
Old Jun 26, 2006 | 09:51 PM
Pandamonkey's Avatar
Re: Wiper (single) dead
I can predict the future.
Hold on.............I'm getting a vision..........yes - it's coming in clear now........
I see...........you - in the rain.........putting two new wiper motors in.
Old Jun 27, 2006 | 01:20 PM
Z28SORR's Avatar
"TWO" new wiper motors?? Funny my car only has one. How about a wiper motor and linkage?
Old Jun 27, 2006 | 01:22 PM
Better install two this time - one obviously didn't work last time.
On second thought - go for four.
Old Jun 27, 2006 | 05:00 PM
Dave89IROC's Avatar
pull the cowl apart, you will probably need the complete wiper "transmission" assm.
Old Jun 27, 2006 | 07:03 PM
Mtrhds94Z's Avatar
Or maybe you got lucky and only stripped the splines on the wiper arm, where it goes onto the shaft..
Take the arm off and check the splines.. the shaft is steel the arm is 'pot metal', so the arm strips first [and since it's a tapered shaft, if you clean both well[ the shaft and the arm] you can usually 'recut' the splines into the arm by tightening the nut..]
Still sounds like you need a wiper motor[or more specifically the board in the wiper motor that controls 'parking' etc.. but it's easier to change the whole motor] since they aren't 'parking' properly..
Old Jun 27, 2006 | 10:43 PM
Craddock's Avatar
I took it apart today and I got pretty lucky with what happened. The socket that keeps the driver side arm connected to the passenger arm disconnected. So I just popped it back on. The blades still sit up a little bit from their resting place, but apparently someone without any knowledge of cars put the arms back on before and set them way above where they belong. So now they work better than they did when I bought the car.
Old Jun 28, 2006 | 05:20 AM
Mtrhds94Z's Avatar
Are they 'parking' properly?[meaning when you shut them off they go down another 3-4" to behind the cowl?]
And yes there are several 'ball and socket' joints on the wiper transmission.. Glad you fixed it..
RX Speed Works
Oct 1, 2015 10:19 PM
autoxr166
Sep 25, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:25 PM
Slayer
Aug 17, 2015 03:55 PM
