deal or no deal. Vortech
Old Jun 23, 2006 | 07:39 PM
User56898's Avatar
My friend wants to sell me his vortech supercharger. It is polished and is set at 8psi. It is the blower itself without the mounting brackets or plumbing. No intercooler either. He said 600 bucks. Should i do it. Will not install for a while but is this a good deal or not?
also:
Vortech blowers need to be plumbed into the oil system right. what is the best way to do this and where can i get the belts, brackets, plumbing, etc for a SBC?
just got him to go to 500. S trim polished blower. 1600 on superchargersforless.com
brand new. Works at supercharger place and he got it at a discount/overstock/etc.
Old Jun 23, 2006 | 08:13 PM
bowtiepwr's Avatar
Re: deal or no deal. Vortech
here is a link to their (Vortech's) SBC kit http://www.vortechsuperchargers.com/...ck.html#system
contact them and they should be able to sell everything to you except the head unit.
Old Jun 23, 2006 | 08:14 PM
boosted-lt1's Avatar
Honestly, 600 for a head unit might be a good deal for some people looking to swap just superchargers. A couple of things....1) there is a heck of a lot more to a blower kit than the head unit. By the time you find a used blower kit minus the head unit....well you might not. 2) Maybe you have access to a machine shop where they can fab. brackets and tubing.....but you need data for this and it will certainly take a lot of time and money. Doesn't sound like a good buy for you, I'd look for a complete kit.
Vortechs use a drain-back to the oil pan. I'm pretty sure Vortech has these instructions on their site.
-Scott.
Old Jun 23, 2006 | 08:27 PM
User56898's Avatar
http://www.superchargersonline.com/p...v=mountingkits
The mounting kit is 900. I don't know what this includes yet but will call them tomarrow (claims its everything minus the head unit). The blower is for 500. He is getting rid of the parts he is not using and really needs money bad. I already inspected it (was going to put on his mach1 motored GT) and it was mint.
From what i herd the oil line installation is not bad at all.
one mroe thing, can i use a procharger blow thru cap over the carb instead.
Old Jun 23, 2006 | 09:09 PM
I wasn't aware they had a mounting kit. Find out what model Vortech it is as well. $500 for a used polished S-trim or bigger in good condition is a good deal.
Your ATI cap will need to be able to fit inline with the Vortech kit. See what or if any cutting/modification needs to be done to run ATI's blow thur setup. Vortech also offers a carburetor encloser which I can imagine is more expensive.
-Scott.
Old Jun 23, 2006 | 09:15 PM
67speeda:
Also make sure the blower spins in the correct direction for you setup and in what position the discharge is in (curved or straight).
-Scott.
Old Jun 23, 2006 | 09:29 PM
User56898's Avatar
Originally Posted by boosted-lt1
67speeda:
-Scott.
okay will do.
here it is online:
http://www.superchargersonline.com/p...ber=V2E128-058
dumb question: what is the correct direction on a SBC?
I have MSD ignition, should i get their boost retard. I am also going to get a better blow though carb and upgrade the fuel system.
for now the set up will sit in garage untill funds are advailable.
just noticed they have different plumbing for both types of discharge.
Old Jun 23, 2006 | 10:19 PM
Just note that S-trims can come in either clockwise or counter-clockwise rotations with either a straight or a curved discharge. I'm not sure what your mounting kit calls for. The head unit could be mounted facing forwards or backwards depending on brackets. My dumb azz can't recall the rotational direction of your SBC (Which should be the same as my LT1 LOL!)
Be sure to check out Vortech's web page as well.
Timing retard should be used in certain applications to avoid detonation. You can pull out a set amount of ignition timing per pound of boost.
-Scott.
Old Jun 23, 2006 | 10:38 PM
User56898's Avatar
okay thxs. Will go and look at it tomarrow to see the discharge/rotation. anyone eles know what rotation i need for a SBC
never thought i would be getting a supercharger....lol
can't wait!
Old Jun 23, 2006 | 10:41 PM
User56898's Avatar
i wonder what kind of power i will be producing. I might as well say good bye to my 10 bolt now....
Old Jun 24, 2006 | 12:13 AM
markinkc69z's Avatar
Turn the pulley clockwise while its facing you. Look at the impeller. If the blades would cut your fingers as you rotate it its going the correct direction. If it was built for a mod motor Ford it won't work as its a reverse rotation unit.
Seriously, unless you have a weird Honda engines rotate clockwise while looking at the balancer from the front.
Old Jun 25, 2006 | 10:23 AM
User56898's Avatar
thx i brought it yesterday. Spins in the correct direction but...
the discharge is straight and faces my driver inner fender. This is perfect for a intercooled set up...
now i need an intercooler
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
Stephen68
Oct 16, 2015 03:50 PM
FryedClutch
Sep 1, 2015 08:24 AM
