ls1 trans cooler
Old Jun 23, 2006 | 12:31 PM
myslowcamaro's Avatar
ls1 trans cooler
couldnt find my answer in search, simple question you think i would know but dont. do ls1's have trans coolers? (a4) and if so, will stock be sufficient for a 3600 stall?
Old Jun 23, 2006 | 12:58 PM
2001NBMZ28's Avatar
Re: ls1 trans cooler
It's integrated into the radiator. I'd add an aftermarket cooler, not expensive and easy to install. The B&M 24K is a favorite.
Old Jun 28, 2006 | 03:38 PM
Capn Pete's Avatar
All automatics have a factory cooler in the rad, but they're barely adequate at best. I (FINALLY!!) just installed a cooler on my car last week, and it was just a couple hours of fiddling around, and it hooked up pretty easily! It's really a cheap piece of insurance I guess?
Old Jun 29, 2006 | 06:27 AM
01Z's Avatar
01Z
I would suggest a trans temp gauge before the install. I have a stewart warner which cost about $46 from Summit Racing. I then installed the B&M mentioned above. Another member claims to have dropped the trans temperature about 20 degrees with the B&M. It is very common for the fluid to go over 200 degrees coming out of the converter. 240 degrees is the magic number where transmission fluid begins to form varnish on the internals.
Old Jun 29, 2006 | 07:47 AM
tfs95z28's Avatar
i have a trans cooler (the biggest one B&M has) and a trans temp gauge and I never have seen the gauge go over 180. It works.
james007moore
Jan 1, 2016 01:14 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Brake_L8
Jan 20, 2015 09:44 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
