Removing A/C help on weight deduction or no??
Old Jun 22, 2006 | 10:41 PM
CamaroRacing12's Avatar
is removing the A/C really worth it? how much weight doesn it remove? i was thinkin about removing it....
Old Jun 22, 2006 | 10:56 PM
Brettinator's Avatar
Re: Removing A/C help on weight deduction or no??
compressor is the heaviest component weighing in at a wopping 15 lbs or so, the rest is aluminum lines, evap & condensor which maybe total around 5 lbs all together. If you have a drag only strip car, sure why not, otherwise keep your ac bro.
Old Jun 22, 2006 | 11:06 PM
StephenDeli22's Avatar
It would make changing passenger side plugs a little easier, cleaner engine bay and probably 35 lbs of weight reduction.
Old Jun 23, 2006 | 12:47 AM
Honda Hunter's Avatar
I live in the middle east and I barelly use mine. The only time it may come on is if a female begs for it. I should just remove it. Car runs like crap with it on anyways though I know it shouldnt.
Old Jun 23, 2006 | 12:54 AM
Zigroid's Avatar
I took out the following:
A/C compressor
A/C lines
A/C condensor
AIR system
and dropped ~50 lbs off the front of the car. I weighed everything I took off.
Old Jun 23, 2006 | 08:58 AM
fastchevy's Avatar
It would help with weight transfer to the rear if anything.
Old Jun 23, 2006 | 10:34 AM
A/C compressor
A/C lines
A/C condensor
AIR system
How tough of a project is this to do? I have been really wanting to do this but I dont want it being another massive project.
Old Jun 23, 2006 | 02:34 PM
fastcamz28's Avatar
Some will tell you it is easy to do. I suppose if u have all the tools, etc, it would not be too bad. It took me almost 7 hours (maybe I am just slow and didn't use a lift), primarily due to bolt access on the rear of the compressor, and the need to soak the bolts, especially the last one w/ MasterBlaster. But i consider it worth the effort as there is significant weight reduction and it cleans up the engine bay, both of which i wanted to accomplish.
BTW, the plugs that are used to block the emission tubes on headers are the same size plugs for the a/c outlet/inlet holes in the unit on the firewall, passenger side.
Hope this helps!
timmy39120
May 8, 2015 11:41 AM
F550maranello2
Apr 1, 2015 11:10 AM
BigWil
Mar 29, 2015 12:24 PM
pologreen97z
Dec 2, 2014 10:42 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
