Wiring the NX Bottle heater.
Old Jun 14, 2006 | 08:14 PM
2000GTP's Avatar
I have a quick wiring question for you guys. For the NX bottle heater, is it okay to wire a 14 gauge wire from the black wire of the relay to the "BATT" terminal in the fuse panel alongside the dash. Also, I planned on wiring a 30 amp fuse inline of this wire. The "BATT" terminal is just a straight 12 volt feed right from the battery, correct? So if this is the case, then it should have no problems keeping up with the current demands of the bottle heater I assume? Thanks for any help offered.
Old Jun 15, 2006 | 01:38 AM
xpndbl3's Avatar
Re: Wiring the NX Bottle heater.
i would imagine you wouldn't want it heating the bottle constantly.
Old Jun 15, 2006 | 05:49 AM
2000GTP's Avatar
No, it wont be run constantly, it will be controlled by a switch. I am only asking about the hot wire from the power source to the black wire of the NX relay.
Old Jun 16, 2006 | 05:55 PM
2000GTP's Avatar
Heres the link to the wiring schematic to give everyone a better idea of what I am talking about: http://www.nitrousexpress.com/Instructions/heater.pdf
Old Jun 17, 2006 | 02:59 PM
2000GTP's Avatar
Wired it up as I planned and all is well and working. I wired 12 gauge wire going from the "BATT" terminal in the fuse panel all the way to the 12 volt wire on the bottle heater relay. I also wired a 25 amp fuse inline of this wire. For the two wires that connect to the bottle heater element, I used 14 gauge wire. Everything else was done with 18 gauge. Long story short, everything works. I just got to hook up the blow down tube, hook up the two wires for the Mallory box, fill up the bottle, and test it out. Smooth sailing from this point on.
calaban
May 18, 2020 06:43 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
