biggest slick
Old Jun 9, 2006 | 03:31 PM
ss97dml's Avatar
biggest slick
biggest slick i can put on a 15x8 rim without modifying the fenderwells? and the car is lowered 1"
Old Jun 9, 2006 | 04:58 PM
Re: biggest slick
Check the manufacturer's recommendations on wheel width vs. tire width. Hoosier will accept a width of 8-10" on their 28x11.5-15 QTP (28.0" diameter). I ran that tire on a 15x10" wheel with a 7.5" BS. It didn't hit on anything until trap speeds went over 125MPH. Then it started hitting on the front/metal edge of the wheel opening, and I had to move the axle back 1/4" to keep the tires from hitting.
The M/T ET Street 28x11.5-15 will also work on an 8" wide wheel, and they shouldn't be a problem because they are only 27.6" diameter. If you go to a true slick like the ET Drag, they will be a problem. I put a 28x10.5-15W ET Drag on the car, and the diameter was way larger than 28".... I ended up cutting about 1.5" off the leading edge of the rear bumper cover, and hammering the sheet metal under the cover.
Whether being lowered is a problem will depend on what the offset of the wheels is. Anything less than 5.5" offset, and the tire lip is going to come right down on the edge or tread of the tire. I've never had any problems with the fender lip, but my car sits 1/2" higher than stock because of the Eibach Drag Launch springs.
https://www.hoosiertire.com/Drtire.htm
http://www.mickeythompsontires.com/strip.html
RUENUF
Mar 13, 2016 03:37 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
WPHIG2
Aug 27, 2015 06:37 AM
whitehooptie
Jul 12, 2015 06:10 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
