When to change belts...
Old Jun 8, 2006 | 03:46 PM
touch109's Avatar
I alreaday have 53000 miles on my car and never had any belts changed and now when i turn the car on it makes a loud squealing noise around the belts .. I add some engine lube and goes away.. So I think i probably need a the serpentine belt. Wanted to know if im right and what belt should I get.
Old Jun 8, 2006 | 06:57 PM
Kwiksilverz28's Avatar
Re: When to change belts...
Engine lube on the belt? Bad idea. I would think it would be the tensioner, but with that oil on them, do the tensioner and new belts. Clean that lube off the pulies before installing.....
Old Jun 8, 2006 | 11:12 PM
touch109's Avatar
I meant something like 10w-40 i used to stop it from making noise.. it only worked for a bit.. I dont think its the sepentine belt its the belt right under it which i think is the tensioner belt (smaller thinner belt) Who makes better belts Gates or acdelco...
Old Jun 9, 2006 | 07:36 AM
AL SS590 M6's Avatar
Moderator
Man you really need to take your car to a mechanic. You NEVER get oil anywhere near a drive belt. And the little belt is the one that runs the air conditioner comperssor.
Old Jun 9, 2006 | 10:48 AM
touch109's Avatar
I meant WD-40 .. was thinking about something else... either way the belts look ok .. to signs of cracks or wear.. Is it time to change them and if so who should i go with gates or acdelco...
Old Jun 9, 2006 | 02:50 PM
steelerfan's Avatar
I would remove both belts,clean all the belt contact areas real good with something that'll cut the WD-40,and replace them with Goodyear Gatorback's. I had squealing several years back & did what I'm suggesting to you & it took care of the noice.You'll like the Gatorback's,better than AC DELCO & Gates.PLease don't ever use anything on or near the belts,not even belt dressing,very bad.
Old Jun 10, 2006 | 09:23 AM
AGREED!
Old Jun 10, 2006 | 10:05 AM
Need4Camaro's Avatar
I had the same problem and my belts looked fine too but over time I believe due to expansion and contraction, belts grow harder and harder aswell as looser and looser. I first figured it was a pulley but after changing to a new belt, the sound went away... It's definately the belts...
Old Jun 10, 2006 | 02:39 PM
touch109's Avatar
Ok purchased new belts from summitracing.com ..didnt know not to put wd-40 around the pulleys, i thought i saw the mechanic do it before... but now is there an easy way to install this and/or I require a special tool...
Old Jun 10, 2006 | 11:29 PM
No, it is easy. Make sure there is a routing diagram, or make one.
Old Jun 11, 2006 | 08:19 PM
steelerfan's Avatar
Should be a routing diagram under the hood near the latch/radiator area,if not take pictures or draw one.No special tools needed,just put a 1/2 in drive socket wrench with socket that fits nut on the front of the belt tensioner pulley or large wrench,& turn wrench like you're trying to tighten(I believe)the nut & it will move tensioner so belt will slip off,do the same when putting belt back on,once you do it you'll be suprised how easy it is !
Old Jun 14, 2006 | 05:06 PM
bshay25's Avatar
yes there is a routing diagram under the hood. You may as well replace the AC belt while youre under there because if it goes bad in the future you will have to pull the main belt off again to change it. BTW These guys are over reacting about the wd-40, you have nothing to worry about.
Old Jun 14, 2006 | 08:50 PM
You have never thrown a belt at 6k+ rpms.....
Old Jun 14, 2006 | 10:53 PM
touch109's Avatar
installed new goodyear belts ... looks like its working pretty good and tried to clean around the pulleys .. thanks for everyones help.. and no i havent thrown a belt at 6k rpms
Old Jun 14, 2006 | 11:51 PM
Glad you changed them.
It is not pretty. WD40 is used to lubricate things. You don't want to do that to belts that are designed to have friction......
